Fill with transparency?
COW Forums : Adobe Photoshop
joe jukes
on Nov 5, 2008 at 8:14:07 pm
Hello. Is it possible to use the fill tool on photoshop (cs3) to make an area transparent, instead of, say, blue?
Thanks, Joe.
William Sticht
Re: Fill with transparency?
on Nov 6, 2008 at 5:32:47 pm
Joe,
Look at your fill property and adjust the transparency. The fill property can be found in the layers panel below transparency. This adjust the transparency of your object and not affect the effects such as drop shadow or stroke. Good luck.
Fritz
