text disappears when saving PDF
COW Forums : Adobe Photoshop
david griffin
on Oct 21, 2008 at 3:32:06 pm
Hi there, a little help would go a long way...
I've just upgraded to PSHOP CS3 and am trying to lay off a flat PDF from a layered PSD to email for client approval.
I'm SAVING AS COPY i.e. no layers. When I open the PDF all the text is missing from the image. I guess it's something to do with vectors but I can't seem to get the right settings simply to flatten everything down to a raster image.
Any thoughts out there?
David
William Sticht
Re: text disappears when saving PDF
on Oct 21, 2008 at 5:20:54 pm
Save the file under a different name (so you dont ruin your original). then flatten you image before creating the pdf. I cant explain what is causing your text to disappear, but this should get your pdf image to your client.
Good luck,
Fritz Sticht
