Creating a border on my header
COW Forums : Adobe Photoshop
Anthony Uccello
on Jul 18, 2008 at 7:29:05 pm
I have a website header that I have designed. However, I want to create an outer border and I am not sure how to do that. I can't just stroke because the border just goes into the non revealed area of the canvas.
The canvas size is cropped to match the header dimensions, but if I reveal all, it gets way to big (as I have BIG images on it that I only want there being a portion of). Here is what it looks like
How can I add a border to the OUTER edges of this header and reveal just the border when I expand the canvas? Is there a way to add a border to image and have the canvas and have it expand automatically? Thanks.
Tom Hepburn
Re: Creating a border on my header
on Jul 19, 2008 at 5:24:17 pm
"Is there a way to add a border to image and have the canvas and have it expand automatically? Thanks."
I'm not completely sure what you mean by the above, but if you apply a stroke in the effects palette, then select the position to "inside" you should get what you want in terms of putting a border on that portion of the image. If the issue is the you're having a problem saving out (in web form) just the header part of your of your image, then I would us the slice tool with guides and save selection. If you're doing a lot of web work, the slice tool is sweet.
T
Anthony Uccello
on Jul 23, 2008 at 3:16:26 pm
Thanks Tom!
Worked perfectly! Didn't notice you could set the stroke to inside!
Many thanks!
