layers
COW Forums : Adobe Photoshop
Ruben Rodriguez
layers
on Jun 14, 2008 at 10:43:39 pm
I'm new to PS. The question is how do you save a color to a layer so that if and when you access the layer, the same color automatically set.
Jeff Kelley
Re: layers
on Jun 20, 2008 at 9:31:34 pm
I don't believe you can, but once a color is used, you can just sample it with the eye dropper to get it back.
Jeff
http://www.willinois.com
Kim Segel
Re: layers
on Jun 30, 2008 at 6:24:32 am
Although you can't make it automatically pop up when you switch to that layer - you can save custom colors to your Swatches tab.
First, make sure the Swatches tab is open (under Window)
Set the custom color you want as the foreground color
Float the cursor over the blank bottom area in the Swatches tab area
When you get the paintbucket, click, give your color a meaningful name and click OK
You can even save and load whole swatch setups - which is great when you're working on a client website with a very specific color palate.
A computer once beat me at chess, but it was no match for me at kick boxing.
--Emo Philips
Ruben Rodriguez
Re: layers
on Jun 30, 2008 at 11:25:14 pm
Makes sense to me. Thanks
