text unreadable after resizing document
COW Forums : Adobe Photoshop
Grady Knight
on Jun 12, 2008 at 4:42:09 am
I am using Ps 7. When I add text to a map I am working on then resize the map to 50% the text becomes unreadable. I believe that I am making the text large enough to read at 1/2 the size but much of the text has ragged edges and the vertical strokes seem twice as thick as they should, looks like blobs from a leaking pen.
I know that there must be something that I should be doing to the text before I resizes the document but not sure what.
Also if I increase the size of the document it also ruins the text edges.
Should I be resizing to my final size before I add text? I would have to do two separate maps for that, need two final sizes.
Thanks in advance if you can help me with this.
Richard Harrington
Re: text unreadable after resizing document
on Jun 13, 2008 at 12:15:07 am
Are you just changing zoom size or the image size.
Text is vector.
Check the anti-alias settings you are using i n the Options Bar
look up antialiasing in help menu
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
Grady Knight
on Jun 13, 2008 at 4:48:56 am
Tried looking it up. Said to turn of anti-alias go to Edit -> Preferences -> General. I look there and cannot find anything about anti-alias. Am I looking in the wrong place?
8mm & 16mm film to DVD
ian schmoel
on Jun 16, 2008 at 10:54:54 pm
Is the file a PSD or are you working with a flattened image? In other words, are you flattening the image and then resizing it?
Grady Knight
on Jun 17, 2008 at 3:30:18 am
Yes I am working with a .psd and yes I flattened the image before I resized it. I am only resizing it because I need one samll for a web page and a larger pdf file for downloads.
Maybe I need to just make two different documents?
Thanks for your help.
Ian Schmoel
on Jun 17, 2008 at 2:18:59 pm
Duplicate the PSD, resize it and then flatten it. Your text should hold up then.
Grady Knight
on Jun 20, 2008 at 5:39:36 am
Thanks, I just got back and will try it out tomorrow.
