Need to edit locked photo
COW Forums : Adobe Photoshop
anandabrata ghosh
on May 24, 2008 at 10:03:44 am
I am using photoshop cs2. I intend to edit the photo.
1) So I open photoshop and then say file-->open--><>. The image is a gif file.
2) But I see that everything is disabled. The layer, filters, etc. The only options available are the tools like crop, select,etc and canvas size, image size etc.
3) I am not being able to do anything with the image. I am not even able create a new layer since the layer menu is disabled.
4) I have also tried to save the file as a tiff and then make changes but the result is the same as above.
Any help how can I unlock the layer/image will be of help.
Anand
Zak Ezzati
Re: Need to edit locked photo
on May 25, 2008 at 1:41:04 am
If you are Mac OS then in the finder select the file and do > FILE > GET INFO and change ownership & permissions and details.
anandabrata ghosh
on May 25, 2008 at 6:24:04 am
I am on windows and I don't think it is a permission issue. Also the file is not read only.
ekim wahs
on May 27, 2008 at 7:47:39 pm
Sounds like you opened a index color mode image. Try converting to RGB.
Mike Shaw
Photoshop QE
joe rugby
on Jun 2, 2008 at 6:00:53 pm
with gifs I often will select all >copy and paste to a new document.
L.O.A.
