save as jpeg with no background
COW Forums : Adobe Photoshop
Jo Richardson
on Apr 30, 2008 at 10:36:27 pm
Is it possible to save a jpeg file without the file defaulting to a white background? If I save the file as a photoshop file I have no problem with maintaining a transparent background but when i save a file as a jpeg it defaults to a white background. If anyone knows how to prevent this from happening, let me know how it's done. Thanks!
Darby Edelen
Re: save as jpeg with no background
on May 1, 2008 at 6:36:03 am
JPEG does not support transparency or alpha channels. The format I will recommend depends a lot on what your image is.
If it's a continuous tone image (photograph) then maybe consider a TIFF with LZW or other compression (it will be larger than a JPEG).
If it is a graphical element (web graphics) try a PNG. If it's destined for the web you can even use a PNG-8 through the Save for Web & Devices dialog to end up with a file smaller, but with fewer colors, than a JPEG.
A PNG can also work for a photograph but your savings in file size won't be as impressive as JPEG.
Darby Edelen
Lead Designer
Left Coast Digital
Santa Cruz, CA
Jo Richardson
on May 1, 2008 at 1:17:40 pm
Thanks, Darby!
That is good information. I think i will try the TIFF route.
