Alpha in TIFF sequence
COW Forums : Adobe Photoshop
Viacheslav Sasykin
on Apr 6, 2008 at 2:59:13 am
Recently working on some green screen footage I’ve got a lot of artifacts in it so I decided to fix them manually in Photoshop. I’ve exported footage as TIFF sequence from AE (both AE and PS are CS3), RGB+Alpha, Millions+ etc., and after I imported sequence in PS I found there is no alpha at all, neither premultiplied nor straight. But if I open every single frame separately it does contain an alpha channel. Looks like Photoshop does not recognize alpha channels in image sequences? At least for TIFF. For now solution was to export as QT with animation codec, there was no problem with alpha. But for future and general information: is it known problem? Is there any solution or may be I was doing something wrong?
Thank you.
Richard Harrington
Re: Alpha in TIFF sequence
on Apr 9, 2008 at 12:51:00 am
What version of PS are you using
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
Viacheslav Sasykin
on Apr 9, 2008 at 2:58:20 am
It`s CS3.
Richard Harrington
on Apr 9, 2008 at 4:26:51 am
If extended... bring in a Movie with Alpha...
if not then use PNG sequence
