Suddenly my Brushes and Eraser are not working properly
COW Forums : Adobe Photoshop
David Strelitz
on Jan 9, 2008 at 8:13:44 am
Pulling hair out - CS2.
Some of the default brushes and the simple Eraser are not working. I seem to remember this happening before but for the life of me cannot remember what causes it.
Simple test
New Canvas- fill with colour no problem but using a simple brush or simple eraser does not work. If I use the pattern type brushes no problem. Opacity etc set to 100%
CLUE Eraser only works if set to Block NOT Brush or Pencil
Help please
David
Vincent Rosati
Re: Suddenly my Brushes and Eraser are not working properly
on Jan 9, 2008 at 4:00:37 pm
Try: Reset All Tools, there is a triangle drop-down menu next to the active tool's icon - not on the tool box, but on the main menu. Just under the File & Edit menus.
Then click the next triangle drop-down, Reset All Tools will be there.
Also, check to make sure the Brush Tool is set to Brush Tool, and not Pencil Tool or Color Replacement Tool.
Just a couple thoughts
Vince
David Strelitz
on Jan 9, 2008 at 5:12:34 pm
Thank You for your response. I had tried resetting the brushes but to no avail. What I have found out is that if I select Basic Brushes, then everything works but many from the other brush sets simply do not work either in Brush mode or Eraser.
Vincent Rosati
on Jan 10, 2008 at 12:46:58 am
I'm at a loss.
Reset All Tools and Reset Brushes are two different functions, on two different lists. Try doing both. It sounds like you tried Reset Brushes.
When the brush is selected in the tool box, try setting the brush Mode to Normal.
If it still doesn't work, maybe start a thread in the PS & AI forum. There's usually more eyes on that forum.
If you do solve the issue, don't forget to post your solution. :)
Vince
Andrea Brown
on Jan 19, 2009 at 3:18:14 am
Hi Guys,
Just wondering if anyone managed to figure out this problem. I seem to be having the exact same problem with my photoshop cs3 software. My erasers do not work other than with the pattern and block brushes.
Looking forward to figuring this out somehow.
Thanks in advance
Andrea
Ray Greenberg
on Jun 15, 2015 at 7:19:52 pm
Yo, reset all tools did it for me! Thanks a bunch. I was doing all sorts of work arounds till I checked here ;--)
Jose Alvarado
on Dec 6, 2011 at 11:04:24 am
DUDE AMAZING!! YOU SOLVED MY PROBLEM !!! IT WAS THE MODE: BRUSH that did it! I almost went crazy bananas there...
Necole Cameron
on Dec 11, 2011 at 10:15:41 pm
Thanks! You saved my life and helped me make deadline!
~May the force be with you.
Renate Hovius
on May 31, 2012 at 3:31:13 pm
hi, had the same problem, thankfully I found this message and problem solved :-) thank you
Meir Sussman
on Jan 4, 2015 at 10:22:28 pm
Dear Vincent,
IT IS 2015 already and your post still saves people from Photoshop CS6 DROWNING :-)))
Thanks a lot.
Heather Hartin
on May 5, 2015 at 1:20:04 pm
I think my Photoshop is different from your version. I don't see the two "tool" options that you suggested to gain access to erasing again. By the way, I did finally notice that my eraser works until I decide to move anything or do anything else with the page, so I've learned to try and erase everything that I think I will need to before I do anything else. Unfortunately, there's one page that has been permanently changed, rather than layered, and I don't know how to enable the eraser. Thank you for your time and help!
Calvin De Beverly
on Jan 9, 2015 at 9:40:24 pm
Using Painter 15 and my pens stopped working. Read this post, reset the tool (have to figure that is why they put it there just to cover "unforeseen" errors) and back to work. Thanks.
Matthew Clift
on Jan 22, 2009 at 12:08:36 am
You may be in quickmask mode. At the bottom of your tools palette there is a circle in a square. Just make sure this is off. The shortcut key is 'Q' so if you accidently hit this you will be in quickmask mode.
Shane Senior
on Jan 24, 2009 at 4:27:46 pm
Ok - pulled my hair out on this too. I have a bamboo pen tablet installed. Using the bamboo mouse (not the pen) - all brushes wouldn't work. I almost uninstalled and reinstalled the program. I then used the eraser on my pen and - viola - it worked. I started to use my regular mouse, and it also worked. Brush works with the regular mouse too.
Sarah Nikolic
on Apr 22, 2009 at 12:06:26 am
Same hear...for the last week or so I haven't been able to use the eraser when it's in brush mode...the block worked fine. I also have a bamboo mouse and pen (not sure if that has anything to do with it) but I followed Shane's advice and used my bamboo pen to erase in brush mode. It worked!....my mouse still doesn't work but at least I can use the brush eraser with my pen. Adobe both sucks and rocks...lol
Regina Pally
on May 1, 2009 at 3:46:57 am
My erase tool does not work when I am using layer adjustments>levels. It works if I paint some color on a photo, but when I try and erase part of the levels adjustments the erasing does not occur, even though I have opacity up to %100. I tried all the suggestions from the other posts but still am having a problem
Holly Marotta
on Jul 23, 2009 at 10:24:48 pm
I was having the same problem; clone stamp, eraser and all brushes would not work. I saw this post and stopped using my wacom tablet mouse --pen worked fine.
THANK YOU!!
Joanne Simoneau
on Jan 25, 2011 at 8:25:07 pm
Thank you. I was going crazy. I too, have the writing pad installed and when I unplugged the usb from the pad... my brushes worked again. Thank you, I was ready to pull my hair out when my paintshop brushes wouldnt work!
Robert Blanker
on Sep 29, 2009 at 12:53:53 am
Took some time when i had the same problem. I dont use a tablet, just normal mouse drawing.
Anyway, to fix the problem;
1. Select the layer in layer listing.
2. Look at the 'lock:' option on layer listing at the top, its below the drop downlist with 'Normal', 'Dissolve' etc. and Opacity dropdown. The first option after 'lock:' is Lock transparent pixels. Make sure its not activated. Should solve your problem...
Anuradha Joshi
on Jan 21, 2011 at 4:46:30 am
Check if you are using Tablets , because the same problem I also faced , but when I remove Bamboo tool , eraser tool is perfectly working ..
check it out if possible.
David Ramirez
on Dec 26, 2011 at 6:41:14 am
Also make sure your layer is not a vector - then the eraser tool will be blocked (crossed circle instead of the tool at the mouse pointer). Choose Rasterize from the layer menu - then the tool will work normally.
Kevin Trench
on Sep 29, 2015 at 9:21:55 am
I have tremendous problems with all my brush tools in CS6... I've even tried re-installing CS6, gone the Reset Tools & Reset All Tools option, etc. I get this "cross haired" problem the moment some of the brush tools exceed 125px and others 400px, up until 1200px I get this "cross haired" problem. PLEASE HELP I'm totally stuck!!! Thanks
Ashii Kumar
on Feb 15, 2016 at 5:41:01 pm
brush and eraser tool is not working in photoshop.please tell me how to fix it.
<a href="https://images.creativecow.net/281184/photoshopproblem.jpg"><img src="https://i1.creativecow.net/u/281184/photoshopproblem.jpg" border="0" /></a>
<a href="https://images.creativecow.net/281184/brushproblem.jpg"><img src="https://i1.creativecow.net/u/281184/brushproblem.jpg" border="0" /></a>
Adam Bales
on Oct 20, 2015 at 7:13:23 pm
Another possible reason that your brush, eraser, etc do not seem to be working is that you have a selection made. If you have a selection made, for example a small area you selected, you won't be able to make change to things outside that selection. On the file menu bar at the top, open the "Select" menu and click "Deselect". Your drawing tools should work now. Enjoy!
Noreen Chui
on Aug 4, 2015 at 8:25:41 am
OMG i struggled with this problem for so long and your method definitely saved me!
