"application failed to start..."
COW Forums : Adobe Photoshop
dakotajoe
on Nov 21, 2007 at 6:03:50 am
I installed Photoshop CS3 (as part of Production Premium CS3) and when I tried to open it, I got a message that said, "This application has failed to start because MSVCRT10.dll was not found. Re-installing the application may fix this problem." I went online and found out that this is a problem that others are having and that downloading and installing this .dll file to the Systems 32 folder would fix it.
I did this and tried to open PS again and got the following message: "This application has failed to start because WINTAB32.dll was not found. Re-installing the application may fix this problem." But I don't find much about this file online and it is only available online for $$. Why am I having these issues?
dakotajoe
Re: "application failed to start..."
on Nov 21, 2007 at 7:17:45 am
Update: I re-installed PS and I still get a message that says: "This application has failed to start because WINTAB32.dll was not found. Re-installing the application may fix this problem."
