Opening Multiple files in a series
COW Forums : Adobe Photoshop
brian pitt
on Oct 8, 2007 at 6:58:57 pm
I have a series of stills that are a part of a stop motion sequence. I have to do some rotoscoping frame by frame. I want to be able to toggle between frames as I correct each one. What is the best way to do this?
ekim wahs
Re: Opening Multiple files in a series
on Oct 8, 2007 at 9:37:37 pm
It would be helpful to know what version of Photoshop you are using.
If you are using CS3 extended you can use File/Open, navigate to the folder that contains the images, select one, then enable the Open as Image Sequence option. The files in the folder will then be contained within the resulting Video Layer and you can use the timeline panel to move between frames.
