speicifcally basic text/layer/rotation of sliced text
COW Forums : Adobe Photoshop
akshav
on Sep 29, 2007 at 8:55:44 am
basic question, i have written some text over a picture, the text has its "own regular" layer, i've sliced some of that text and moved it, slightly, now, i would like to rotate the part i've moved slightly, closer to the intial word I sliced it from, and up about 70 degrees counterclockwise, so the word appears to radically kearn.
TIAdvance
Vincent Rosati
Re: speicifcally basic text/layer/rotation of sliced text
on Oct 6, 2007 at 9:35:59 pm
Once you have the part you want to rotate selected (marquis tool, or Select/Load Selection, press Ctrl+T or Edit/Free Transform. You can than manipulate the object.
