Watermarking/branding images with file name
COW Forums : Adobe Photoshop
cinaed
on Sep 21, 2007 at 6:29:43 am
Hello everybody!
I
Richard Harrington
Re: Watermarking/branding images with file name
on Sep 21, 2007 at 1:56:11 pm
Try File Scripts Image Processor
ekim wahs
on Sep 24, 2007 at 9:31:15 pm
Scripting would handle this nicely.
here's a bit that will add a type layer with file name
// set rulers to pixels and save original for resetting
var originalUnits = app.preferences.rulerUnits
app.preferences.rulerUnits = Units.PIXELS
// add the pixel position for the left side of your text block below
var textLeftPosition= 60
// add the pixel position for the bottom of your text block below
var textBottomPosition= 60
var typeLayer = app.activeDocument.artLayers.add();
typeLayer.name = app.activeDocument.name;
typeLayer.kind = LayerKind.TEXT;
typeLayer.textItem.size = 48;
typeLayer.textItem.position = [textLeftPosition, textBottomPosition];
typeLayer.textItem.contents = typeLayername;
// return units to original
app.preferences.rulerUnits = originalUnits
You could use insert menu item action to call the script. Save the above text as a jsx file, and call it from file/scripts/browse
Also, here is a nice script to use as a starting point for processing a folder of images. Insert the operations that you need to perform in the area indicated.
http://www.tranberry.com/photoshop/photoshop_for_geeks/openFolderTemplate.j...
Jeff's Photoshop for geeks area is a nice intro to scripting in Photoshop.
Mike Shaw
Photoshop QE
Cinaed
on Sep 25, 2007 at 5:03:04 am
Ah, thanks a lot!
This will probably save me hours of work, and even enable my company to be able to offer yet another service ;)
-Kenneth
Rob Goldstein
on Mar 4, 2009 at 10:40:08 pm
I Have never used scripts before. Can anyone tell me how I apply this script in photoshop? Unfortunately I look at this and all I see is Greek.
Thanks so much for the help. If I can get this to work it will save me so much time.
paul Hinderer
on Sep 2, 2009 at 4:40:32 am
Hi Richard,
I have tried to use your file location watermarking script in SC4 - but I keep getting an error message for line 17 - (typeLayer.textItem.contents = TypeLayername;. The script does load a text layer in the name of the file, but no text appears on the page. I am loading the script by "scripts - browse". Can you let me know if I am doing something wrong.
Cheers
ekim wahs
on Sep 3, 2009 at 11:00:04 pm
try adding the line
var layerName = typeLayer.name
before the line
then change
to
typeLayer.textItem.contents = layerName;
Mike Shaw
Photoshop QE
Jed Rosenberg
on Mar 15, 2010 at 7:34:33 pm
This is working for me, but how do I adjust the color? I'd like to make it white.
ekim wahs
on Mar 15, 2010 at 8:11:41 pm
set the foreground color before the type layer gets added.
app.foregroundColor.rgb.red = 255
app.foregroundColor.rgb.green = 255
app.foregroundColor.rgb.blue = 255
will set the FG color to white
Mike Shaw
Photoshop QE
Jed Rosenberg
on Mar 15, 2010 at 8:18:29 pm
thank you!
Jed Rosenberg
on Mar 17, 2010 at 7:34:42 pm
One more question ... i'm trying to make it 'right justified' but my script is not working.
typeLayer.textItem.justification = justification.right
Josue Smart
on Mar 8, 2012 at 11:12:52 pm
Hi, do you know how can i get rid of the file extension(.jpg) in the watermark?
Evagoras Mandrides
on Oct 30, 2011 at 10:05:57 pm
I have just used this script and would just like to say what a stroke of genius!!!! the has saved me inputting 300 file names manually! Line 17 did cause a problem but you fix was spot on!!! well Done!
