color match large amount of images
COW Forums : Adobe Photoshop
Doohnibor
on Aug 29, 2007 at 6:23:49 pm
hi,
is there a way to "batch color match" images.
i got about 60 images which all seem to different exposure etc.
i know how to do it manually, but i am hoping for a simpler solution.
is there maybe a different application which specialises on this problem?
thanks alot : )
Abraham
Re: color match large amount of images
on Aug 29, 2007 at 8:19:18 pm
Try creating an action for the match command with your settings and play it on all your images as you ctrl tab through them.
Abraham
Doohnibor
on Aug 31, 2007 at 10:10:20 am
hi abraham,
i'll probably end up doing what you suggested. actually i was hoping for a "better" solution, but it seems like there is none.
btw: i answered yesterday already two times to your post. but it never showed up and i always got an error message in my browser. is CC now incompatible with opera? it used to work before. now i use IE and it works wiout a problem.
Abraham
on Aug 31, 2007 at 3:28:13 pm
Additionally once you create the action you can use the batch command under the file menu > automate.
This will allow you to apply an action to a folder or all opened files through PS.
Abraham
