How come I can't save as a jpeg?
COW Forums : Adobe Photoshop
Josh J. Johnson
on Aug 6, 2007 at 3:06:39 pm
When I go to save as jpeg isn't listed in the pull down? what am I doing wrong do I have to download a plug in?
thanks
MarkofCain
Re: How come I can't save as a jpeg?
on Aug 7, 2007 at 2:52:46 am
What are your options?
It could be possible that you have a setting on the image that restricts the number of options for saving the file e.g. the mode of the image. What is the mode setting? Perhaps it is still possible to use File --> Save for Web...
HTH,
Mark Cain
Sarasota, FL USA
May Tulin
on Aug 9, 2013 at 12:48:36 am
OMg thank you, I just had the same problem, it was this detail!!!
Cora Smith
on Aug 3, 2015 at 5:39:26 pm
Thanks, I was looking for this recently... :)
dutchm913
on Aug 11, 2007 at 1:27:36 am
if your trying to save a GIF file as jpeg it won't let you,, simply open image ready with the same pic then save as jpeg ..or open with piant and save as jpeg
Abraham
on Aug 15, 2007 at 5:34:35 pm
Another way to save a gif as a jpeg is change the mode to RGB instead of indexed color. Image Menu > Mode
Abraham
Ben Armitage
on Jan 23, 2011 at 9:57:00 pm
Hi mate
Listen you dont need to download any plugins
I had this problem aswell when i started out........
If your saving files in either RGB or CYMK anything more than
8 bits/Channel wont let you save as a JPEG file.....
so theres your answer, go to
IMAGE-MODE- and just make sure the 8 bits/channel is ticked
Hope This helps you
Jen Dorman
on Feb 23, 2012 at 6:05:05 pm
I am saving a jpg for web & devices and then when I go to name it and save it where I can use it, there is no save button.
Jannatul Shumi
on Dec 4, 2015 at 9:51:01 am
Make sure you are saving the file using save for web devices. Which options you are seeing during saving the file? Have clicked on the drop down?
