Solo a layer?
COW Forums : Adobe Photoshop
Solo a layer?
on May 31, 2007 at 2:39:28 pm
How do you "solo" or make active only one layer in PS?
I don't know the term PS uses so it is hard to use the help.
solo is an audio term for mixers.
Darby Edelen (wuzelwazel)
Re: Solo a layer?
on May 31, 2007 at 2:47:40 pm
You can opt/alt click the visibility (eyeball) icon next to the layer you want to solo. It's not quite as elegant as the system for soloing layers in After Effects, but it works.
Darby Edelen
DVD Menu Artist
Left Coast Digital
Aptos, CA
Jim Kanter
Re: Solo a layer?
on May 31, 2007 at 3:57:05 pm
The visibility switch is in the Layers palette to left of the layer name.
The eyeball is an icon to indicate an object's visibility.
Clicking the eyeball makes the object appear/disappear.
Alt/Option clicking makes all the other objects appear/disappear.
You can also click and drag through a number of visibility boxes to turn layers' visibility on or off.
Jim Kanter,
Digital Film Institute
© 2018 All Rights Reserved
