Eraser draws with BG color
COW Forums : Adobe Photoshop
charlie b
on May 8, 2007 at 1:49:56 am
Anyone know why my eraser, instead of erasing, applies whatever color is selected as the background color? I have totally deleted the program from my PC, yet when I re install it, the problem persists. how can I troubleshoot?
TiffaniB
Re: Eraser draws with BG color
on May 11, 2007 at 2:25:03 pm
When you erase something, you are basically creating a mask. Or in other words, the eraser tool DELETES the portion of the layer you've used the eraser tool on. Therefore, whatever is BEHIND it will show up in the spot you've erased. This would be another layer or your background layer.
If you don't want the background to show, you have to either turn off/hide the background, put a layer between the BG and the eraser layer that shows what you WANT to see through the erased hole, or change the background color.
Tiffani B
John Stockton
on Oct 26, 2011 at 5:07:47 pm
That is not the answer. It's drawing the background colour. What ever is selected for a background colour is being painted onto the canvas. It has nothing to do with other layers.
