CS2 dimension problems
COW Forums : Adobe Photoshop
gerardmanvuca1
on May 4, 2007 at 7:17:20 pm
Hi, when I work in CS2 and i set an image to be for example 10 cm X 10 cm and double check on the grid to make sure the dimensions are right, the exported file does not match the dimensions I had the set the image to, It's really frustrating,
Basically, the dimensions in CS2 do not correspond to the dimensions of the exported file.
If anyone has a clue about this problem, please help,
thnks
wuzelwazel
Re: CS2 dimension problems
on May 5, 2007 at 2:15:47 am
The important bit of information missing from your post is: how are you exporting it? What is your destination format? Is this for print?
