Double selection possible?
COW Forums : Adobe Photoshop
Gary Weaverton
on Apr 17, 2007 at 12:07:22 am
Hello,
When I make a selection using my Lasso Tool, and then want to make another (separate from the first) selection on the same layer/image, I lose the first selection I made.
Is it possible to keep the first while making the second?
Gary
P.S. I'm using CS
Gary Weaverton
Photographer/Illustrator
gary.weaverton@gmail.com
TiffaniB
Re: Double selection possible?
on Apr 17, 2007 at 8:55:36 pm
Yes, hold down the shift key while you make your second selection. That will add it to your first selection.
Tiffani B
Gary Weaverton
on Apr 17, 2007 at 11:08:47 pm
Wow, that was easy!
Gary
Gary Weaverton
wuzelwazel
on Apr 19, 2007 at 12:17:33 am
Just so you know what else is available, if you hold down opt/alt while using a selection tool you can subtract from your selection area as well.
