Batch Adjust Color for 50 images PS CS2.
COW Forums : Adobe Photoshop
Bob O Dell
on Dec 11, 2006 at 12:29:23 pm
How do I. Batch Adjust color PS CS2.
I have 50 jpg images in one file on my PC.
I want to change the color, "Hue-Saturation Filter" of all images at one time.
Can I do this?
Do I need a plug-in to do this?
Thanks Bob
Timothy Kurkoski
Re: Batch Adjust Color for 50 images PS CS2.
on Dec 11, 2006 at 10:15:20 pm
If you want to apply the same adjustments to each image, then yes, this is relatively easy. Create an action that makes the adjustment, then run a batch with that action.
If you're unfamiliar with creating actions or running a batch, I'd recommend you look up those terms in the Help files first. It's not terribly hard, and the Help files explain it better than I can. If you have more questions after reading and trying it out, certainly post back here and we'll see if we can straighten you out.
