Selecting type to make alpha problem
COW Forums : Adobe Photoshop
Mark Sullivan
on Oct 31, 2006 at 10:13:01 pm
I have text with a drop shadow. There is no background. I want to use this in AVID so I save it as a psd file. AVID opens it fine, but the drop shadow appears white instead of black.
If I try to use a black background and command-click the icon to select it and then generate a alpha channel, the drop shadow isn't selected. Same if I have applied a stroke to the text.
Suggestions will be most appreciated.
Thanks, Mark
cowcowcowcowcow
Jim Kanter
Re: Selecting type to make alpha problem
on Nov 5, 2006 at 3:48:36 am
Apply the drop shadow in the Avid.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
Mark Sullivan
on Nov 6, 2006 at 9:39:54 pm
I'm on Symphony Nitris - it doesn't do soft offset drop shadows.
Thanks though.
cowcowcowcowcow
Jim Kanter
on Nov 14, 2006 at 8:35:28 pm
Photoshop layer styles are stored separately from the pixel content so they are usually not correctly drawn by non-Adobe apps. You should convert them by rasterizing the layer and then you should be able to select the shadow pixels normally as you would the text pixels.
Jim Kanter,
