cannot save EPS file as anything but photoshop raw or TIF
COW Forums : Adobe Photoshop
amsterchapman
on Aug 20, 2006 at 3:53:53 pm
Hi, new to photoshop, which i probably shouldn't be. A client gave me an .EPS file which has several of their Icons on it. i can open the file in photoshop, and choose a resolution (i am using 3000 pixels) and then PS rasterizes it. I then need to be able to save these back out as a PNG with a transparent background, but have not been able to as the only options it gives me are to save as a copy, either RAW or TIF. i have been able to save out with other files but not this one...
help?
thanks
matt chapman
amsterchapman
Re: cannot save EPS file as anything but photoshop raw or TIF
on Aug 20, 2006 at 4:39:08 pm
as a follow up, when i open the file with only 200 or 1000 pixels it will let me save out
Timothy Kurkoski
on Aug 21, 2006 at 6:43:34 pm
3000 dpi is a HUGE image. The formats you're choosing may not support resolutions that high. Use the Image Size dialog to control the image dimensions if you must import at 3000 dpi.
