Transparent Images
COW Forums : Adobe Photoshop
jbmTJL
Transparent Images
on Jul 22, 2006 at 10:46:09 am
Hello,
I'd like to know how I can preserve transparent images within a photoshop file, then import them into Illustrator without being gigantic (file size)
The only file that works that I know of is a psd (photoshop) file that has not been flattened.
any help from the COW would be much appreciated.
Thanking you,
Joseph
Timothy Kurkoski
Re: Transparent Images
on Jul 24, 2006 at 5:40:31 pm
Why do your file sizes need to be small? For most design work, you're better off not using compressed formats.
You can try using a 32-bit PNG file out of Photoshop, though I'm not sure how Illustrator will treat it. You can also use a TIFF file with compression turned on.
JPEG 2000 is another option, though I don't know if Illustrator supports it, and at the very least you have to grab the plug-in for Photoshop off the install CD.
Otherwise, not many compressed files support alpha channels. PSD really is your best bet.
jbmTJL
on Jul 25, 2006 at 10:40:15 pm
Thanks Timothy,
I was creating a file for print . . . However, I wanted to send a proof via email and the file was about 8MB.
So I had to adjust a low-res file in Photoshop to reduce the file size.
I was hoping that there could be another method to create a trasparent (alpha) channel that didn't seem so awkward.
Thanks for clearing that up for me.
Take Care
Joseph
