Photoshop to FCP
COW Forums : Adobe Photoshop
smuggla2002
Photoshop to FCP
on Apr 26, 2006 at 11:14:16 pm
I'm having trouble with the transfer of photoshop PSD files to Final Cut Pro. I can pull the files in there without a problem, but once i put them in my timeline they lose quality. How can i get these photoshop pictures in my timeline without losing qualitly?
Nathan Troester
Re: Photoshop to FCP
on Apr 27, 2006 at 7:56:12 pm
What are the pixel dimensions of your images? If the images are smaller than your sequence dimesions and you're resizing them, you might see some loss in quality.
Another thing to check is the RT (real-time) settings in FCP. There's a little drop-down button on the top left corner of the sequence which, if set to "low" or "medium" will influence how your footage is viewed. This will be especially the case if you are looking at the sequence on an NTSC monitor. The "low" and "medium" settings only play one field. (This is actually really useful if you are trying to preview lots of layers in real time.)
cowcowcowcowcow
Jim Kanter
on May 2, 2006 at 2:34:52 pm
The sequence codec can also impact the quality of the image.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
