Quick mask mode leaves transparency areas
COW Forums : Adobe Photoshop
mballom
on Apr 11, 2006 at 5:31:34 am
I used the quick mask mode (QMM) for the first time for selection. After i switch back to normal mode the selection is fine, but i copy/past in new canva the picture looks strange with sort of transparency areas here and there.
How to fix that? Or how to better use the QMM to avoid that?
Timothy Kurkoski
Re: Quick mask mode leaves transparency areas
on Apr 11, 2006 at 6:15:20 pm
You're probably using a brush with a wide feather. That can cause you to end up with some areas where it looked like you had brushed out part of the image, but really some very faint red area was left in QMM. Use a harder-edged brush, or just clean it up after you paste it (this is where the "quick" part of QMM comes from; it's not the most accurate).
mballom
on Apr 11, 2006 at 6:45:50 pm
"Use a harder-edged brush, or
just clean it up after you paste it"
Greta Thank you. How do you actually "clean up" the image after paste?
Timothy Kurkoski
on Apr 11, 2006 at 9:38:32 pm
Once you have a look at the pasted image and can see the stray pixels (turn off other layers if necessary), use tools like the Eraser or Lasso to select and/or delete them.
