Help! How do I use an alpha channel to get the transparency from a photoshop image??
COW Forums : Adobe Photoshop
BRussell
on Feb 25, 2006 at 12:41:40 am
Hi, I have a photoshop image -- a feathered title against black. Instead of a transparency it has an alpha channel. How do I use the alpha channel to get the title with transparency? If I ctrl-click the alpha channel to get a selection, then copy-and-paste from the title, the black background gets mixed in with the selection. I know there is a way to do this, but I haven't a clue how. Help! Thank you!!!
"THE LOST SKELETON OF CADAVRA" -
And more...
harman
Re: Help! How do I use an alpha channel to get the transparency from a photoshop image??
on Feb 25, 2006 at 7:04:38 am
Do this (u can probably skip straight to the alpha channel step since you said one already exist, but just in case, I left all the steps in there -- and you don't have to make the mask at the end) The video link is at the bottom of the post:
EXTRACTION
cowcowcowcowcow
Jim Kanter
on Feb 25, 2006 at 5:08:37 pm
1. Duplicate the layer and turn off the bottom (original) layer.
2. Select the top layer (the copy).
3. Selection > Load Selection and choose the Alpha Channel.
4. Invert the selection.
5. Delete.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
cwise73
Thanks! That is what I was looking for! NT
on Mar 10, 2006 at 2:34:43 pm
NT
