comp window is dark since crash- urgently need help
COW Forums : Adobe Photoshop
rp
by
on Feb 21, 2006 at 8:45:48 pm
Hello,
Recently my graphics PC crashed- ever since- my comp window is noticeably dark and I think the color is off. When I work on a file- then move to the "save for web" the image is correct- I know this- because I tested the image against a correctly working PC right next to the newly crashed PC.
Oddly, when I move the work to the save for web- I get proper values and brightness etc.
Is there a way to set set the comp/work area brightness etc?
Thank in advance
rp
Timothy Kurkoski
Re: comp window is dark since crash- urgently need help
on Feb 22, 2006 at 12:25:18 am
It sounds like your color settings are off. Go to Edit > Color Settings and choose one of the default presets, like US Prepress Default. (Save for Web doesn't use color management, so it's not affected by these settings.)
If that doesn't help, you may have a damaged color settings file or preferences, a damaged color profile, or a damaged Photoshop install.
For the first, trash your prefs.
For the second and third, start by reinstalling.
rp
by
on Feb 22, 2006 at 4:20:36 am
thanks much- looked inm the color settings- when i use my monitor default- the color is deaed on with everything else- so i'm good to go.
thankfully!
thank you again for great help.
rp
