True 3D text?
COW Forums : Adobe Photoshop
stevem1928
True 3D text?
on Jan 2, 2006 at 11:09:58 pm
I can not seem to find the command to make a 3d text layer with depth (extrude). I can manipulate the layer in 3d, but the layer has not depth. I have found something in the EFFECTS > 3D Channel that has variaables for the "Z depth". Changing the Z dimension does not seem to affect the depth of the text.
I am using AE 6.5 and am well versed in other 3d programs such as 3D Max.
Jim Kanter
Re: True 3D text?
on Jan 3, 2006 at 6:09:52 pm
There is no native capability to give objects true 3D volume. For that you need something like Zaxwerks Invigorator or a true 3D app.
AE gives you 3D compositing space. Every layer is still essentially a flat screen on whose surface content appears.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
Jim Kanter
Re: True 3D text?
on Jan 3, 2006 at 6:11:58 pm
Whoops, wrong forum (thought this was AE).
You can simulate 3D by applying layer styles like Bevel.
Jim Kanter,
stevem1928
Re: True 3D text?
on Jan 6, 2006 at 3:54:27 pm
Whoo. I did post this in the wrong forum. I have been trying to find this post for the last week. I just found it today. I did intend it to be be in AE.
Thanks for your reply. I will need to use 3d max for part of my intro.
