need text to form a circle
COW Forums : Adobe Photoshop
jeff
by
on Dec 7, 2005 at 5:25:14 am
i've seen this done before but i'm not sure how to do it myself. text is wrapped around so that it forms a circle. i wanted to know how to do this to use it in motion graphics.
Timothy Kurkoski
Re: need text to form a circle
on Dec 7, 2005 at 6:24:12 pm
If you're going to do this with After Effects, AE has an option to set a text object to follow a mask. Simple.
In Photoshop, you can draw a path, and then when you put the text cursor over it and click, you'll be able to type along the path. (You'll know you're choosing the path because the cursor will change so the baseline crossing I-bar becomes slanted.) To draw a circle for this purpose, select the Ellipse tool and in the Options bar click on the Paths option on the left (the box in the middle with a pen over the rectangle). Hold shift while you drag to draw the circle.
jeff
by
on Dec 8, 2005 at 1:41:01 am
i don't know what i'm doing wrong but once i create the circular path, i select the type tool put it over the circle's outer line and it will not follow the path.
i'm working with ps 7, so you know.
also can you move the circular path once you draw it?
Timothy Kurkoski
on Dec 8, 2005 at 5:40:04 pm
Ah, that helps. It's always nice if you state what version of the application you're using in your original post. Tools and options can be different between versions of the application.
In PS7, this is not something easily accomplished. This page will probably be helpful:
http://www.digitalscrapbookplace.com/forum/showthread.php?t=4575
Especially the last post.
