My keyboard shortcuts do not work on PS CS?
COW Forums : Adobe Photoshop
Cornelius Matteo
on Nov 14, 2005 at 6:59:04 pm
Hello,
I just installed my PS CS and the keyboard shortcuts do not work, any suggestions? For instance, I am used to Cntl A for Select all, etc.
I am using Microsoft OS too.
Thx
Cornelius
Timothy Kurkoski
Re: My keyboard shortcuts do not work on PS CS?
on Nov 14, 2005 at 8:13:42 pm
There are a couple of possibilities. One is that you may have the wrong keyboard shortcut set selected. Go to the Edit menu > Keyboard Shortcuts and set it to Photoshop Defaults.
Otherwise, your preferences may be damaged. Hold down CTRL+ALT+Shift while Photoshop starts to clear them out and start fresh.
Cornelius Matteo
on Nov 14, 2005 at 10:53:45 pm
Thanks for your reply.
I checked the the default was ok. I also tried Ctl Alt Shift as I loaded PS CS but I still cannot use any keyboard shortcuts. Any ideas?
Thx
Timothy Kurkoski
on Nov 15, 2005 at 11:53:33 pm
Afraid not. You might want to call Adobe about this one.
