UI is too small on Photoshop CC 2015 on 4K Monitor
COW Forums : Adobe Photoshop
Chris Kay
on Jun 5, 2016 at 7:36:48 pm
I just bought an ASUS ZenBook, which has a 4K screen. I installed Photoshop CC 2015 yesterday and I noticed that the UI is way smaller than I am used to. I have set scaling to 200% (if I set it to 100%, the UI goes from being very inconvenient to unusably small). I have set the text UI to "Large," but it makes no difference. What can I do?
Reggie Sutton
Re: UI is too small on Photoshop CC 2015 on 4K Monitor
on Jun 5, 2016 at 10:45:00 pm
Hello Chris Kay. I had the same problem when I purchased my Microsoft Surfice Book pro, and the same problem my 4K monitors.
There are only two options that I know of that's available at this time.
#1 you could sckil down your monitor to 1080 P That's should be in your display setting.
#2 Is a little more involved. Follow these instructions to the letter. I hope this helps you like it did for me.
How To Make Adobe Software Display Larger On High Resolution Monitors
Adobe App Scaling on High DPI Displays (FIX)
http://www.danantonielli.com/adobe-app-scaling-on-high-dpi-displays-fix/
I would also consider leaving a donation for this information.
I hope this helps. Peace & blessings.
