Photoshop CS6 will not open psd, jpg, tif, or RAW files
COW Forums : Adobe Photoshop
medard taber
on Jun 24, 2015 at 7:31:59 am
I suddenly cannot open any photo files in Photoshop CS6 64bit. I can't open by right click>open as, or by opening within Photoshop with File>Open or from Lightroom 4 using Photo>Edit In>Photoshop CS6 or using Bridge. If I reboot my computer I can open one photo and then I can open no more. The files are fine. They all open in Lightroom. I've made no changes to my computer settings, etc.
Herbert van der wegen
Re: Photoshop CS6 will not open psd, jpg, tif, or RAW files
on Jun 24, 2015 at 8:52:42 pm
Try resetting your Photoshop preferences. Hold down while starting up Photoshop.
System: Win7 64bit - i7 920@3.6Ghz, p6t Deluxe v1, 48gb (6x8gb RipjawsX), ATI 7970 3gb, EVGA 590 3GB, Revodrive X2 240gb, e-mu 1820. Screens: 2 x Samsung s27a850ds 2560x1440, HP 1920x1200 in portrait mode
tommy palmer
on Jun 26, 2015 at 7:34:34 am
1. Open "My Computer" from your desktop. Double-click your hard drive.
2. Open "Documents and Settings."
3. Open the folder labeled with your user name.
4. Open "Local Settings" followed by "Temp."
5. Scroll down to the files beginning with "Photoshop" ("PS" for older Photoshop CS builds). This will be followed by a series of letters and numbers.
6. Double-click each "Photoshop" ("PS") temp file to open them in Photoshop CS. This is the only way to identify which temp file contains the project you wish to recover. Luckily, because when Photoshop shuts properly it deletes its temp files, there should be no more than three or four.
7. Select "Save As" from the "File" me
8. If you can’t restore Photoshop file you may use more strength solution http://www.psd.openfiletool.com/ PSD Open File Tool
