Adaptive Wide Angle - Failed To Calibrate
COW Forums : Adobe Photoshop
Paul Benson
on Feb 10, 2015 at 5:05:14 pm
I see whispers of this error on the web, but no real information, so I realize this may be a 'long-shot' post.
I am using Adaptive Wide Angle in order to straighten some edges of some artwork photos. I am using the 'fisheye' correction. More often than not, I draw the line to use as my 'basis' and then when I drag the center point to have the curve match the one in the photo I receive this error message:
"Failed to Calibrate. You may need to adjust the constraint more precisely or try another constraint."
I have tried this on both 32 and 64 bit. I will say that it will work in some areas of the same photo, but not at the critical points where I truly need it. I have no idea what is lacking during the calibration, so I'm unsure what to adjust. Since my corrections are usually on the edge, I thought that may be the issue, but I added some whitespace around the photo and still get this error.
Any ideas?
Pauley
Paul Benson
Re: Adaptive Wide Angle - Failed To Calibrate
on Feb 10, 2015 at 7:07:10 pm
Oh yes. This is with CS6 (DVD).
Adobe Photoshop Version: 13.0.1 (13.0.1.3 20131024.r.34 2013/10/24:21:00:00) x64
