Photoshop type tool measurement is different than the ruler measurement?
COW Forums : Adobe Photoshop
Leslie King
on Aug 28, 2014 at 5:07:08 am
My Photoshop type tool measurement is different than the ruler measurements and I can't figure out how why. Using the ruler I set my guides at 12.5 millimeters then I added type set at 12.5 millimeters. But the type was way too small so I measured with the ruler tool and the type is only 9.2 millimeters tall.
I've tried several different fonts, and checked all the type tool settings. Does anyone know what could cause this? It's driving me crazy!
Here's a screen shot...
Angelo Lorenzo
Re: Photoshop type tool measurement is different than the ruler measurement?
on Sep 15, 2014 at 9:11:39 am
[Leslie King] "Does anyone know what could cause this?"
Not all glyphs take up full point height, it's a part of font design to deal with descenders, ascenders, and other characters.
You'll just have to scale it manually with the transform command.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
Leslie King
on Sep 15, 2014 at 1:10:09 pm
I appreciate your answer but this is happening with every font and it wasn't always like this. Has anyone else had this problem?
Angelo Lorenzo
on Sep 16, 2014 at 7:03:07 am
[Leslie King] " it wasn't always like this"
Er, nope. I'm going to have to disagree, it has to do with cell height/point size vs glyph height and I checked back on Photoshop CS 5.5. If it use to work differently then it must have done so at a point beyond my recent memory.
72pt Aral Black 'X' is ~51.5 points high. If I type it's equivalent of ~18mm into the type size box to create a second X then Photoshop insta-converts to ~51.5 points, ok great. Type the letter and it's smaller than the first. Photoshop is properly converting mm to points but, again, a letter rarely takes full height.
http://www.thomasphinney.com/2011/03/point-size/
I checked all type related options and menus, no options related.
Angelo Lorenzo
