Symmetrically/Porportionally duplicate/resize an object to fit in another
COW Forums : Adobe Photoshop
Jeff Krieger
on Aug 15, 2014 at 8:36:26 pm
Hi, I have a rectangle. I would like to create a symmetrical border inside that rectangle. Duplicating the layer and scaling it doesn't work. It's not proportional. How do you do this?
Thx.
Jeff Krieger
Re: Symmetrically/Porportionally duplicate/resize an object to fit in another
on Aug 15, 2014 at 9:47:46 pm
In Illustrator it's offset path
Jeff Hinkle
on Aug 15, 2014 at 9:51:56 pm
Couple ways:
If you just need an inside border, apply the Stroke effect set to Inside. adjust color and thickness to taste.
If you need a separate rectangle, make a selection from your original rectangle, choose Select>Modify>Contract and set the Contract By value to how thick you want the border. You now have a proportional selection from your rectangle.
It is easier to destroy than to create.
More fun, too.
