3D Cilinder transparency
COW Forums : Adobe Photoshop
Chris Van Velthoven
on Aug 6, 2014 at 3:01:15 pm
Hi all,
I've created a cilinder and wrapped an image around it, but i want to make the cilinder transparant so that i can see through it. Does anyone know how to do this?
Thx!
Rob Hal
Re: 3D Cilinder transparency
on Sep 24, 2014 at 7:21:01 pm
Could you show an example of your cylinder. I asume just setting the transparancy of the layer is not enough? It also depends on your background, maybe you want to add refraction as well? Some more info would be nice.
Chris Van Velthoven
on Sep 25, 2014 at 8:41:07 am
Thank you for your reply.
Cylinder image
As you can see in the image, the cylinder has a label wrapped around it, but the white in the label should actually be transparant, so that you can see throught it, while the text and logo etc, still remain sharp and visible. The material should also have a plastic feel.
If anyone knows how to do it in photoshop, please tell me! :)
