Photoshop Inverted Mask size difference
COW Forums : Adobe Photoshop
Iris Moleman
on Jun 30, 2014 at 9:41:42 am
Hello all,
I've got a problem with Inverting masks in photoshop. If I invert a mask, the new mask is a bit smaller than the original mask.
If my layers are two identical images with a mask applied to one layer and the inverted mask applied to the other layer, I’d expect to see the whole picture. But there is a small empty ‘edge’ around the mask-shape.
I can’t explain it really well, but i hope this screenshot will make it clear. There's a small edge around her face.
I set all the refine-edge and feather options to 0, so that can't be the problem I guess.
I also found out the problem isn't the inverting itself; If I duplicate the mask to another layer without inverting it, the duplicated Mask is a bit bigger than the original mask.
Who can help me?
Thanks in advance!
Iris
