How do I cut an image into jigsaw pieces and separate layers
COW Forums : Adobe Photoshop
Lars Hansen
on Jun 27, 2014 at 10:37:56 am
I would like to take a black and white template of jigsaw pieces that I downloaded from the web and use it cut up an image into individual jigsaw pieces that are each on their own layer.
How do I do this?
Thank you for your help
chris brett
Re: How do I cut an image into jigsaw pieces and separate layers
on Jun 27, 2014 at 4:52:14 pm
Hi
-----think you need either ---
1 ) black and white matte for each layer ( piece )
OR
2 ) vector for each layer ( piece )
Also, depending on what you want to achieve, there is also a jigsaw option with the shatter effect ( that comes with AE ) which might be useful - example attached
---------------------------- Chris --
Lars Hansen
on Jun 30, 2014 at 1:20:57 pm
cheers, as I want to use it in AE I'll look at that option first.
chris brett
on Jun 30, 2014 at 1:38:41 pm
Hi Lars -
-- if you want to use it as a wipe its pretty good I think -- I gues you could reverse it as well to get an image to assemble
-- will have another go at attaching example image
should be here
------- chris --
Mike Bedford
on Jul 3, 2014 at 11:34:18 pm
There's a Photoshop plug-in called "Puzzle Pro" that is designed specifically for this task.
Free digital imaging ezine
http://www.plugsandpixels.com
