How would you make this?
COW Forums : Adobe Photoshop
Melissa De Vera
on Oct 17, 2013 at 6:45:24 pm
I want to make letters that are striped like this: http://images.clipartof.com/Clipart-Rainbow-Letter-A-Royalty-Free-Vector-Il...
I will be making lowercase "m" and "d". Any suggestions on the best method to create this effect?
Jonathan Ziegler
Re: How would you make this?
on Oct 18, 2013 at 5:59:11 pm
It'd be easier in Illustrator I think, but since we're in the Photoshop forum, create your initial letter as a pen line, centered in the letterform with the pen tool. Use the stroke tool (Edit >> Stroke) create a large stroke around the letter (you could use layer styles for this, too, I suppose). Duplicate the letterform you just made and drop it BELOW the present layer. Scale the path (Edit >> Transform Path >> Scale), change the color and use stroke to change the color. Rinse, repeat for each bit.
Hope this helps.
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293
