need some he*lp with either a css to grd conversion or the ability to refine grad editor
COW Forums : Adobe Photoshop
Jon Iverson
on Aug 13, 2013 at 4:31:34 pm
I was trying to create a custom gradient using the dropper and an existing image in CS 6 when I came across this unique website:
http://www.colorzilla.com/gradient-editor/
The ability to import an image and get a gradient from it is just what I needed, however I don't see any way to get this into PS CS6. Is there any way to convert the CSS to the .grd file PS needs? Or, is there a similar gradient maker that allows save in .grd format?
An alternative might be to copy the actual gradient settings by hand into the PS gradient editor, but the gradient colorzilla created has so many stops and colors that this doesn't appear to be feasible.
Really in a jam on this one. I don't see any way to make the gradient maker in PS more finely tuned (i.e. much larger so I can add more stops, etc), and this looked like a possible alternative but I'm stuck with the format.
Thanks in advance for any help.
Jon
Jonathan Ziegler
Re: need some he*lp with either a css to grd conversion or the ability to refine grad editor
on Aug 14, 2013 at 2:17:59 pm
Well, in the absence of a specific tool, I think you may need to just do the work. Can you post the CSS gradient code? Making gradients by hand in Photoshop isn't that bad.
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293
Jon Iverson
on Aug 14, 2013 at 10:25:38 pm
Thanks. I ended up just doing that- inputting the stops and opacities manually. There were 100 stops and I had to try and get them as close together as possible. In the end, the resulting gradient didn't work out anyway, but it was an interesting experiment in case a situation arrives in the future where I need to do this.
Herbert van der wegen
on Aug 16, 2013 at 7:53:44 pm
You might like this plugin next time:
http://css3ps.com/
Convert your layer styles directly to css3!
System: Win7 64bit - i7 920@3.6Ghz, p6t Deluxe v1, 48gb (6x8gb RipjawsX), ATI 7970 3gb, EVGA 590 3GB, Revodrive X2 240gb, e-mu 1820. Screens: 2 x Samsung s27a850ds 2560x1440, HP 1920x1200 in portrait mode
