Photoshop crashes on launch
COW Forums : Adobe Photoshop
Walter Miale
on Aug 6, 2013 at 5:56:08 pm
I'm running Photoshop CS2 on an iMac with OS 10.5.
Out of the blue, the application just crashed, and now crashes on launch. Is there an alternative to re-installing?
If I do have to re-install, are there some tips I should know? Do I have to un-install first?
Of course my deadline is day before yesterday.
Thanks.
Jeff Hinkle
Re: Photoshop crashes on launch
on Aug 6, 2013 at 6:33:44 pm
You can try trashing your preferences file. Go to
/Users/[Username]/Library/Preferences/Adobe Photoshop CS6 Settings and delete the file Adobe Photoshop CS6 Prefs.psp
You might also want to trash /Users/[Username]/Library/Preferences/com.adobe.Photoshop.plist
You can also try holding down Command-Option-Shift when starting Photoshop to do the same thing, but since I didn't know how far in the startup you were getting before it died, I figured the manual route was better.
Hope this helps!
It is easier to destroy than to create.
More fun, too.
Walter Miale
on Aug 6, 2013 at 7:48:18 pm
Thanks very much. Before trying your suggestions, I tried re-launching PS for about the seventh time. Guess what!? It worked............. I'll save trashing prefs for next time.
