Remove excess gray space within an image
COW Forums : Adobe Photoshop
Brian McLaren
on Feb 20, 2013 at 4:53:11 am
I have some large collections of images: columns of 8 to 10 images across with as many as 40 to 60 rows. These are exported from a program called CatDV Pro. Between each row is gray space -- my problem is that I need to reduce that gray separator between the rows to make a better visual display and also to get it to fit on the page of the book. I have about 30 to 40 of these image collections to process.
Some things I cannot do: reduce the size of the gray separators in CatDV Pro -- not possible. It is only possible to export the entire page of images together. Sure I could export each individual image but that would be a garganuan task -- not practical.
I don't want to cut and paste indivdual images or rows. Sure, it's possible but not at all practical.
I have tried Content Aware Scaling and it is not uniform enough. Some rows squish before others. I know about protecting some area in Content Aware Scaling but that doesn't seem practical either, not with 40 rows. Maybe I'm missing something there.
What I start with:
What I want to end up with:
Open to any and all labor saving/time saving suggestions and hoping to expand my understanding of Photoshop CS6. Thanks.
Jeff Hinkle
Re: Remove excess gray space within an image
on Feb 20, 2013 at 3:22:34 pm
Are all of your source files uniform? Same number of rows, rows and separators the same height/position every time? Image dimensions constant? If so, you could set up a simple Action to select/copy/paste/move each row into position in a new document, then run a Batch Process to let Photoshop do all the work for you. I did a test run on your small sample image above and it worked out well. Maybe not the most elegant solution, but it's quick and free.
It is easier to destroy than to create.
More fun, too.
Brian McLaren
on Feb 21, 2013 at 6:47:26 pm
Thanks, I'll give that a try.
I thought of actions, but the problem I saw was that every selection needs to move "X" pixels down the image. I don't know if I'll be able to do that consistently. Any ideas?
Jeff Hinkle
on Feb 22, 2013 at 2:52:08 pm
Provided everything is consistent, size-wise, you could add a step to your Action to add guides in your newly opened source file, and turn on snapping. I'd also recommend setting the Marquee tool to a fixed size to keep that consistent as well. Then as you're recording the action, Photoshop should track the moves accurately. Might take a little pre-Action math, but it should work. If you want to post one of your source images, I could try to put together a starter Action for you.
More fun, too.
Darby Edelen
on Feb 23, 2013 at 12:04:54 pm
[Brian McLaren] "Sure I could export each individual image but that would be a garganuan task -- not practical."
Is the exporting the gargantuan task? The set up in Photoshop would be simple with the Automate > Contact Sheet script. It takes a little while to run but requires very little "you" time.
Darby Edelen
