Smoke Brushes
COW Forums : Adobe Photoshop
steve white
Smoke Brushes
on Feb 16, 2013 at 8:42:01 am
Hi all
Just downloaded some free smoke brushes and can't get them to work in cs6 im on a pc.They loadup ok but when i add one to a black background the brush is solid and has no transparency to it.Am i missing some settings?
Jonathan Ziegler
Re: Smoke Brushes
on Feb 16, 2013 at 5:54:18 pm
Can you give the link to where you got the free brushes? I'll try them out and make sure the problem isn't the brushes. :)
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293
steve white
Re: Smoke Brushes
on Feb 17, 2013 at 12:12:28 am
Sure
http://www.brusheezy.com/brushes/1830-real-smoke-photoshop-brushes
But have tried a few and all react the same but have tried a brush that is not a. Smoke brush and everything works ok
Many thanks. Steve......
Jonathan Ziegler
Re: Smoke Brushes
on Feb 17, 2013 at 4:28:24 pm
Ok, so here's what I did:
Download and unzip the brushes.
Launch Photoshop
Create a new file (I used Photoshop Default) and click the brush tool.
Go to the brushes palette, load your brush ABR file, select one of the brushes, and voila, it looks like it works.
The problem is likely a setting on your end or a problem with the download. Try downloading again?
Can you list the exact steps you took?
Jonathan Ziegler
520-360-8293
steve white
Re: Smoke Brushes
on Feb 18, 2013 at 12:10:43 am
Seem to have fixed things for now it's only happening with new brushes I have downloaded.the fix is to not load the brushes but to replace them ie only load the brush I need not add to the brushes already in my pallet
Bug?
Thanks for your help Steve.......
Jonathan Ziegler
Re: Smoke Brushes
on Feb 18, 2013 at 5:41:02 pm
Steve, that's a little odd. What version are you using? I'm on CS3 on this machine (its the one I tested it on). I haven't tested CS6 (it's at the office), but I add brushes at least every month to some degree and I haven't seen that. Maybe talk to Adobe?
Jonathan Ziegler
520-360-8293
Thomas Alexander
Re: Smoke Brushes
on Feb 26, 2013 at 10:49:38 am
Make sure your plugins are loaded and have use a white background.
Thomas Alexander | Independent Cinematographer
Soulman Films | Nicosia Cyprus | +357-97697640
