CS6 duplicate frame hotkey
COW Forums : Adobe Photoshop
Jacquie Trowell
on Feb 14, 2013 at 6:51:17 am
I am doing animtion in Photoshop CS6 (Windows) using the video timeline. I can select "duplicate frame" from the "layer/video layers" menu but I can't find this command in the keyboard shortcuts window. I desperately need to add a hotkey for this command - it's taking me forever to use the menu every time I want to duplicate the frame I've just created. Anyone know how?
Jeff Hinkle
Re: CS6 duplicate frame hotkey
on Feb 21, 2013 at 2:42:14 pm
I'm imagining this is the same on Windows as the Mac, but some of the fine details might be a little different. Go to Edit>Keyboard Shortcuts... (Ctl_Alt-Shift-K on Windows, I think?) and set the popup menu to Application Menus. Twirl down the Layer line and scroll down to Timeline. There you should see a line for Duplicate Frame. Click on it and add whatever keyboard shortcut you would like. Click Accept, hit OK, and you should have your custom keyboard shortcut.
It is easier to destroy than to create.
More fun, too.
Jacquie Trowell
on Feb 21, 2013 at 5:54:12 pm
Hey Jeff
Thanks for the response.
I've done everything you suggest but there is no line for duplicate frame.
An oversight by Adobe?
Jeff Hinkle
on Feb 21, 2013 at 6:04:18 pm
Whoops. Correct procedure, just in the Keyboard Shortcuts window, twirl down Layer, then Video Layer, not Timeline. You should see a line item in there for Duplicate Frame.
More fun, too.
Jacquie Trowell
on Mar 12, 2013 at 1:14:19 am
Hi Jeff
Thanks so much!! You have saved me hours of misery!
Cheers
Jacquie
ps sorry about the late response - I was away for a couple of weeks.
Jeff Hinkle
on Mar 12, 2013 at 2:05:09 pm
No worries. Glad we got it working for you.
More fun, too.
