Add Rainbow Anodizing to Metal
COW Forums : Adobe Photoshop
Wade Stubanas
on Jan 4, 2013 at 5:01:49 pm
I am looking for a way to add a rainbow anodization to a metal object, preferable a needle, in photoshop.
See example:
Jonathan Ziegler
Re: Add Rainbow Anodizing to Metal
on Jan 5, 2013 at 6:35:29 pm
Easiest way is to create a "map" of the rainbow coloring you want to add and put that in a new layer on top, mask out the areas you don't want to have rainbow, likely set the blend to "color" and then vary the opacity.
You can make a bubbly rainbow pattern with a huge variety of tools - render clouds, add a rainbow gradient map, use ripple, glass or some other distortion, or swirl or what have you, etc.
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293
