Smooth drawing lines with Wacom Intous
COW Forums : Adobe Photoshop
Kyler Boudreau
on Dec 30, 2012 at 1:31:53 am
Hey Photoshop pros...I just purchased my first Wacom. Have never done the tablet drawing, but have done a ton of drawing with normal pen and pencil.
My setup is Apple Mountain Lion, Photoshop CS5 and the small Wacom Intous 5.
Problem: My lines in Photoshop have jagged edges when I draw. I messed with settings a lot, and can't figure out what I'm doing wrong.
I've seen other drawings from these things, and their lines are smooth. I've tried crazy hight DPI settings, but still doesn't fix it.
Any ideas? Thanks!!!!!
________________________
Kyler Boudreau
Theater Eleven Pictures
http://www.theatereleven.com
Darby Edelen
Re: Smooth drawing lines with Wacom Intous
on Dec 30, 2012 at 8:43:01 pm
[Kyler Boudreau] "Problem: My lines in Photoshop have jagged edges when I draw. I messed with settings a lot, and can't figure out what I'm doing wrong."
Can you upload an example picture of what you are seeing?
Darby Edelen
Jonathan Ziegler
on Dec 31, 2012 at 4:32:29 pm
You may have your lines set too hard with no anti-aliasing. Also, try just using the default Photoshop 5x7x300dpi. I have a Wacom tablet and I use it for PS, Painter, Illustrator, and a few other apps. When you set up your brushes and such, you may need to tell it what to do with pressure (ie: pressure on the pen varies size, opacity, etc.).
Please send samples so we can all be wrong. When you send a sample, please include brush and image details.
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293
sanjeev ramanathan
on Dec 31, 2012 at 5:55:06 pm
Are you sure you are not drawing with the pencil tool.
Beekeeper
