the same color is showing up different
COW Forums : Adobe Photoshop
ben wolfinsohn
on Nov 28, 2012 at 6:27:51 pm
all my colors are a bit messed up on documents that i thought all had the same color in them. in the 2 files here according to the color picker they are the same color. and if i copy one and paste it into the other they are the same. but they are not at all the same. if i take a screen grab of them they are very different. its the same monitor profile and color space and bit rates. any ideas?
thanks!
the 2 photoshop color squares - http://www.stopfollowingme.com/colors.zip
Jonathan Ziegler
Re: the same color is showing up different
on Nov 29, 2012 at 5:59:04 pm
According to my Photoshop, color1.jpg uses the Adobe RGB 1998 color space, but color2 doesn't have a color space assigned. I went to Edit >> Assign Profile and chose Adobe 1998. Now they both match. Color space makes a huge difference in the final appearance - I generally use Adobe 1998 where appropriate as I find sRGB to be pretty poor.
Jonathan Ziegler
http://www.electrictiger.com/
520-360-8293
ben wolfinsohn
on Nov 29, 2012 at 6:13:36 pm
thanks! wonder how that even got changed like that if i was the one who created the doc and never used that feature before.
Jonathan Ziegler
on Nov 29, 2012 at 6:41:30 pm
I've done it several times. Whenever you do a File >> Save As, you have the option of including the color profile or not. I will deselect this anytime I create images for the web (most browsers ignore color profiles anyway so its wasted data) and I usually forget to reselect it later. ;)
Glad it worked. :)
-Jonathan
Jonathan Ziegler
520-360-8293
