Smart Filters & Adjustments PER LAYER
COW Forums : Adobe Photoshop
Jonny Webb
on Nov 23, 2012 at 12:05:18 pm
Hi, how do i apply filters on a per layer basis for many layers...
a typical file i have to work is a collage.
There are numerous photos (a photo per layer) in a Group (the folder icon). Each photo has a mask, so only the relevent part is visible, and all the photos have been arranged as the author wants it...
My problem is i need to adjust most of the photos - colors, brightness, sharpness, etc. but if i use adjustment layers everything below changes, and i really dont want to change each layer into its own smart object.
Is there an easier way to apply a filter to just the active layer.
(sorry if the terminology is off)
Thanks, Jon
Jonathan Ziegler
Re: Smart Filters & Adjustments PER LAYER
on Nov 24, 2012 at 3:50:30 pm
Yep, use clipping layers. Create your filter layer, then hold the mouse between the original layer and the new layer, hold down Option (Control or Alt on the PC, I don't remember) and the cursor will turn into a sort of pair of circles, a black one on a grey one. Click between the 2 layers and the top one is clipped by the one below. This will apply the adjustments only to the visible part of the layer. Anything below won't feel the effects.
You can also do this when creating your adjustment layers by clicking on "Use Previous Layer to Create Clipping Mask" just before creating the layer. You can stack several layers, each clipped to the original layer.
-Jonathan
Jonathan Ziegler
http://www.electrictiger.com/
520-360-8293
Jonny Webb
on Nov 27, 2012 at 11:25:19 am
Thank you.
And another method i found (thanks to JZ pointing me in the right direction)...
select layer, click on Add An Adjustment layer, and click at the bottom of the properties box on the square & arrow "This adjustment clips to the layer".
