Creating wet reflective surface
COW Forums : Adobe Photoshop
Greg Flory
on Oct 22, 2012 at 12:38:12 pm
I would appreciate ideas on creating a wet reflective surface for imgaes. Are plug-ins or actions available to create this look?
Attached is a sample image with desired result.
4833_wetsurfacelook.jpg.zip
Thanks.
Greg Flory
Jim Arco
Re: Creating wet reflective surface
on Oct 26, 2012 at 1:29:37 pm
A "wet and reflective" look is probably going to require more creativity and judgment than can be coded into a software plug-in.
When something is wet, it appears to change color and brightness depending on the material and the surface finish. For instance, masonry or wood usually get darker. However, the moisture on the surface also reflects the light sources in the scene. In your example, the reflections show up as diffused vertical bars or stripes similar in color to the light sources in the scene. (Had the camera angle been different, the reflections would be at a different angle.) In other scenes, you'd want to add 'puddles' to large areas of pavement, a blue haze for large open backlighted areas, or 'glistening drops' on grass and leaves to create an illusion of a recent rain.
I would use curves on a masked layer to create brighter or darker "wet" surfaces, and also to change their color to create a wet look.
Jim
