Color Picker/ Curves
COW Forums : Adobe Photoshop
Ashley Ripka
on Jun 19, 2012 at 3:07:48 pm
Okay, so I am trying to color correct an image in photoshop to export as a preset for after effects. I have found this tutorial online that seems pretty awesome with this color correction technique, but I have CS6 on a MAC and this guy is using CS3 on a PC.
What I am trying to do is sample a highlight, midtone, and a shadow. I have the colors sampled and I have my curve graph open. I need to go back and select the points I have already created to add an anchor point onto my curve line. In his tutorial he says he just control->clicks and it adds the point to the graph.
I have tried control->click, command->click, option->click and nothing works.
So basically, in CS6 does anyone know how to use the color picker tool to select the color and add an anchor point to the graph?
Cory Livengood
Re: Color Picker/ Curves
on Sep 6, 2012 at 4:56:39 pm
Did you ever find a solution to this? I am having the same problem.
© 2018 All Rights Reserved
